Nick wrote:When installing the crank seal, use gasket sealer on the outer seating surface of the seal. This makes the seal easier to install, will help prevent damage during installation and will also help prevent leaks.
As with any engine, excessive oil leaks can also be caused by combustion pressure leaking past the rings and pressurizing the crankcase.
CB77 - Oil leaking woes
Don't be surprised if it pops out. ..................lm
