On the brake side, the clip is welded onto the inside of the fender strut. I think I recently saw the clip for the speedo side on eBay.
Edit to add: here you go http://www.ebay.com/itm/NOS-Honda-44852 ... AS&vxp=mtr
You'll need a 5mm x 10 screw to mount the clip, part #93500050100a, also available on ebay.
Clutch Cable Routing
Thanks Seadog! I just saw the brake side didn't have a bolt hole like the speedo side, so I was wondering . . . glad you cleared that up. I found the horn tag and a good grommet! I had them in a bag to be installed after paint. Gotta find a rattle can to match horn cover and carb covers. Will go to paint section later.
1967 305 Dream, 2006 Triumph Rocket III
