Clutch Cable Routing
1967 CA77: Currently my clutch cable is routed outside the frame and outside the gas tank as seen in pic. It works fine, but I see pics with the routing coming from underneath the tank where it is neatly hidden away. Anyone know the correct routing? Does it go into the frame from the headlight area, then back out again, or does it just sit along side and underneath the gas tank without going into the frame? Any help would be appreciated. Thanks.
- IMG_6066.JPG (184.88 KiB) Viewed 4655 times
1967 305 Dream, 2006 Triumph Rocket III
Looking good. I see you need a rubber grommet thingy for the wires on your horn. Most of them I've seen are so badly weathered that they look as if they've been melted. I don't know where to get them for the 305s, but CSM Restoration has them for the 450 K0 and, except for the color, it looks the same as for the Dream & Superhawk. I recently ordered one for my Superhawk and will let you know if it fits and if it might fit the Dream.
http://www.claussstudios.com/id45.html
Funny, I just took it out today when I routed my cable. Yes, looks like death! (Fixing to post a new topic on brake and speedometer cable routing under appropriate heading. I think they are routed incorrectly too.
- Grommet.jpg (26.53 KiB) Viewed 4572 times
