Dick Eastman
Post by Dick Eastman » Tue Nov 08, 2016 12:02 pm
last few
ENGINE BUILD 016 (Medium).jpg (75.22 KiB) Viewed 8191 times
ENGINE BUILD 017 (Medium).jpg (70.78 KiB) Viewed 8191 times
ENGINE BUILD 018 (Medium).jpg (70.4 KiB) Viewed 8191 times
Dick Eastman
Post by Dick Eastman » Tue Nov 22, 2016 6:46 pm
A few more small details finished. I made an arbor to restore roundness to carb inlet - one end of the tool is .007" smaller than the finish end [end w/ the smaller radius on cnrs]; It works well, using plenty of grease. When done, I OD bored the outside diameter for clean-up, may work up some sort of filtered velocity stacks. I also re-worked the exhaust clamps, as the holes in them would clear an 8mm bolt - too sloppy. I figured the spread on the 6mm exhaust studs and bored the holes to accept some bronze bushings I made; also restored the spot face on the clamps so that the bushing head would seat squarely. I painted the clamps with a hi-temp ceramic paint, then baked them in my wife's oven [while she was at work, of course!]. A;so have some carb parts ready for zinc plate - bought a Caswell plating system - this will eliminate numerous trips to platers, and can proceed at my own pace - will have pics of finished results.
engine build 007 (Medium).jpg (75.92 KiB) Viewed 8050 times
engine build 006 (Medium).jpg (69.09 KiB) Viewed 8050 times
engine build 005 (Medium).jpg (61.53 KiB) Viewed 8050 times
engine build 004 (Medium).jpg (63.57 KiB) Viewed 8050 times
engine build 003 (Medium).jpg (67 KiB) Viewed 8050 times
Dick Eastman
Post by Dick Eastman » Tue Nov 22, 2016 6:50 pm
Last couple pics, also shows heli-coil in carb fuel inlet
engine build 002 (Medium).jpg (59.52 KiB) Viewed 8042 times
engine build 001 (Medium).jpg (38.92 KiB) Viewed 8042 times
Post by G-Man » Wed Nov 23, 2016 3:56 am
Dick
Lots of fun machining going on there.... :-)
Dick Eastman wrote:Last couple pics, also shows heli-coil in carb fuel inlet
Muddy
Post by Muddy » Wed Nov 23, 2016 5:58 am
I dunno where you guys get all those machines, tools and skills, but I'm very envious of what you do. Well done!
Muddy
Thanks.
Regards
Muddy
'64 C72
'63 C72
Post by Seadog » Wed Nov 23, 2016 11:13 am
I agree. But even if I can't do that stuff myself, it's fun to see others' accomplishments. As Muddy said - well done.
Muddy wrote:I dunno where you guys get all those machines, tools and skills, but I'm very envious of what you do. Well done!
Muddy
Dick Eastman
Post by Dick Eastman » Wed Nov 23, 2016 7:29 pm
G-Man wrote:Dick
Hi Graham - the really fun part is seeing the project come together. I will be receiving my wheels from Buchanan Spoke and Rim next week, buying the Excel shouldered WM1 front, and the WM2 rear. These are made from 7000 series aluminum. I bought the 9 guage rear stainless spokes/nipples, the 10 for the front.
