1965 cl77
Sproket
1965 cl77
Post by Sproket » Mon Sep 19, 2016 7:57 am
New here.....hi
Picked this up this weekend and this seems to be the place to be..
I've always liked these early ones and always kept a look out for one...I was going to look at an xt500 on sunday but I stumbled on this Saturday and it won me over....was a non runner .I was told it ran a few months back and now was being a pig to start and to rev any sense. .
All it was was the carbs needed a good clean ....sort a poorly fitted plug cap and some nice fresh fuel....it does run sweet and sounds fantastic when you twist open the baffles
The problem I had then was when you turned the lights on the engine died and in turn blew the fuse....
This seems a common fault and was just the po wiring up the instrument light wrong....you know the one With 2 greens coming from it...
Mot hopefully this week
All I need is a pair of mirrors and hope fully it's gonna be some fun...
What I liked and why I did choose it was it seems most of the awkward parts are still present....
We all love pictures so here's a few
Sproket
Post by Sproket » Mon Sep 19, 2016 7:59 am
Ok it seems I cannot post pics from my phone
I will pop some up later when I have abit more IT time
G3
New project
Post by G3 » Mon Sep 19, 2016 11:07 pm
Welcome Sproket,
Hopefully you'll find help in the time of need here on the forum. There are a bunch of swell guys and even one gal I believe, who will be very helpful to you.
Have fun with your new project and don't hesitate to ask questions.
Sproket
Post by Sproket » Tue Sep 20, 2016 12:41 pm
Cheers for that...
Here goes for pictures
Sproket
Post by Sproket » Tue Sep 20, 2016 12:49 pm
A few more
It does sound fantastic when you open those baffles up
Sproket
Post by Sproket » Tue Sep 20, 2016 1:09 pm
Ok first question
It had a new clutch fitted in 2011 but has only coverd 100 miles since...the action is at the very bottom of the lever so you only have a small movement before it releases ..
Is there an easy adjustment to get it up to middle of the lever movement
Thanks in advance
jgger
Post by jgger » Tue Sep 20, 2016 8:27 pm
On the kick starter side that big slotted screw looking thing is for the cam/lifter for the clutch. The bolt below it is the lock for the cam.
I believe you need to loosen the tension at the handle first. Then take up the slack at the cam adjustment and tighten the lock bolt. After that you do the fine adjustment at the handle.
I am sure someone here knows the proper way to adjust it, be patient and I"m sure someone will chime in soon.
BTW very nice looking bike.
