Signal not flashing
Robbie63
Signal not flashing
Post by Robbie63 » Thu Apr 28, 2016 6:43 am
When I put my signal light on they light up as they should,they just don't flash but I can hear the flasher makin a horrible noise. I have been taping it in an attempt to get it to work,but no luck.just woundering if this sounds like a bad connection or needin a new one.thanks for any advice. Rob
Post by Seadog » Tue May 03, 2016 9:02 am
Why not clean all of the connections first, then take it from there; a new flasher isn't expensive or hard to find - any auto parts store has them.
Robbie63
Post by Robbie63 » Wed May 04, 2016 9:51 am
Yes your right sea dog a good cleaning of the wiring may be all that's needed ,that's all I did for my lights to work
Post by G-Man » Wed May 04, 2016 11:04 am
You might need to pull the can apart and clean the contact points on the inside.....
They look just like mini versions of the ignition points.
Post by Seadog » Wed May 04, 2016 12:08 pm
What a good idea, especially if it's an original Honda flasher and I suppose it might well be, since Robbie63 is from Canada.
G-Man wrote:You might need to pull the can apart and clean the contact points on the inside.....
Post by G-Man » Wed May 04, 2016 2:20 pm
I always try to save things if I can, but I just purchased a NOS one with bracket from a dealer in the UK that is clearing out some stuff.
Post by Seadog » Wed May 04, 2016 2:34 pm
Nice find, G. Hope you were able to snag some other good stuff too.
G-Man wrote:Seadog
