Cb77 kick-start cover
I have a 69 superhawk and I've been trying to get the clutch to work. The lever pulled hard and the gears would grind when I tried to engage. I took apart the kick-start cover and noticed some slack in the adjuster. I got a new adjuster and I'm trying to put it back together and I noticed the adjuster hits the magneto when I pull the cable a little bit. I tried adjusting it but I don't get anymore slack out of the cable. Is this a common thing?
- jleewebb
from my archives
Original author is Loudmouse...
Turn cable adjusters in all the way.
On right case loosen the bolt with a 10mm wrench.
Turn the large gray adjuster left/right a couple of times.
Turn it right to stop then back 1/8 inch.
Adjust the lever for apx. 3/8-1/2 inch slack. .............lm
'62 CB77. "It's a rider."
