Steverino's CB77
Steverino
Post by Steverino » Mon Oct 12, 2015 3:38 am
Hi Jensey
Paint and dirt? In the disassembly pictures? You can Presume I assembled the motor using basic mechanical hygiene. I don't like doing work over. Have a great day!
malcolmgb
Post by malcolmgb » Mon Oct 12, 2015 1:58 pm
I think what he was getting at is you seem to have painted the gasket face, that should be bare metal (masked off), along with paint/debris in the threaded hole.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Steverino
Post by Steverino » Mon Oct 12, 2015 2:39 pm
Thanks Malcomb.
I plug openings rather than masking with tape. Spark plug holes with old spark plugs, intakes and exhausts with rags. It may not be everyones way but thats how I do it. Before I install the tensioner I will wipe down the flange with thinner as I had planned. It is my habit to test fit all screws nuts and bolts with my fingers before putting a driver to them to check for clear threads and to avoid galling. My clumsy method must work. This is only my first CB77 but my sixth old Honda refurb or restoration and although I've had to remove many dozens of seized and rounded fasteners I have yet to ruin a thread.
Steve
Steverino
Post by Steverino » Mon Oct 12, 2015 4:54 pm
These gaskets showed up yesterday so I spent some time today cleaning up the pump and screen housing. The old gaskets were real stubborn and it took at least a half an hour with the wire wheel to get the screen housing clean. After a short nap I will head back down to the shop and take care of that flange. I am pretty sure, (I'll double check though.) the threads are okay now.
ImageKIMG0899 by Steve Steverinomeister, on Flickr
Steverino
Media Blasting the Engine Cover
Post by Steverino » Tue Oct 13, 2015 10:09 am
Steverino
Post by Steverino » Tue Oct 13, 2015 5:08 pm
Steverino
Post by Steverino » Wed Oct 14, 2015 1:45 pm
The "tensioner gasket" showed up today. Ha Ha, not even close.
ImageKIMG0929 by Steve Steverinomeister, on Flickr
