1964 CA77 Restoration
Back on track. Benly rear winker lenses seem to work. They're cheap repros from Thailand and not extremely well made, but with a little filing to remove the casting waste, they fit pretty well. I need to make gaskets, find screws and mount a bulb socket. I think I'll use LED bulbs. Wires with the proper colors are in hand.
- IMG_0888.JPG (91.42 KiB) Viewed 2155 times
Just tinkering lately. I've stripped the covering from the wiring harness to make changes in the wiring to accommodate a new rectifier/regulator. It's all back together now, but I need to find multi-pin connectors. I've exhausted the local auto parts stores, so it looks as if I'll have to order on-line. And wait. Again.
Since I'm fiddling with the electrical system, I decided to mount the rectifier/regulator using the old rectifier bracket. I had to fabricate an inner bracket from aluminum flat stock to do it. It came out o.k. and does not interfere with the side cover. I could have just drilled a hole in the frame, but, first, I didn't want to do that and second, I like that the old bracket retains the air filter bolt and provides a place to tuck away wires from the solenoid and coil.
More as it happens.
I think I'm going to start a thread for the Superhawk to keep track of changes.
More as it happens.
- IMG_0916.JPG (116.87 KiB) Viewed 2128 times
Nice work. Good to see the fins placed vertically to maximize convection.
Seadog wrote:Just tinkering lately. I've stripped the covering from the wiring harness to make changes in the wiring to accommodate a new rectifier/regulator. It's all back together now, but I need to find multi-pin connectors. I've exhausted the local auto parts stores, so it looks as if I'll have to order on-line. And wait. Again.
More as it happens.
