Tail Light Stuck on Bright.
deafanddiabetic
Post by deafanddiabetic » Wed Sep 30, 2015 12:56 pm
Hey everybody,
I've mostly got the CA72 Dream together after an engine and transmission rebuild and a new COAt of paint. I'll post pictures when it's together!
I marked all my wiring harness leads before disassembly so that I could just plug and play when putting it back together. I decided to solder and seal all the wires to be safe.
My only issue is that my tail light is stuck on bright, or acting like it's "pulled". I tried switching the wires at the tail light brake lever switch, but that didn't make a difference either. Could I have gotten the two wires going to the tail light switched up?
It was working for a short while, like had it's normal running light, then I pulled the lever switch down and it went bright like it's supposed to, now it just stays bright.
Not sure what the issue is?
1964 CA72
1974 BMW R75/6
1969 CL450
Post by Seadog » Wed Sep 30, 2015 1:10 pm
Sounds like the brake light switch is bad. Take it off and test it with a multimeter. See if the spring loaded plunger on the underside is stuck.
deafanddiabetic
Post by deafanddiabetic » Wed Sep 30, 2015 1:17 pm
I'll give it a good cleaning tonight, it's looking a little worse for wear. The plunger moves freely but it sounds like there's a mechanism underneath it that might be getting rusty/stucky?
1964 CA72
1974 BMW R75/6
1969 CL450
Post by Seadog » Wed Sep 30, 2015 2:50 pm
Definitely clean and test it. There isn't much below the switch that's complicated enough to go too wrong. The little arm below the switch is attached with a shouldered bolt, so I don't think it could get rusty enough to lock up, but give it a look too.
Plenty of used switches on ebay. If you want new and don't mind non-stock, you can search for non-Honda replacement, like this: http://www.ebay.com/itm/Emgo-Rear-Stop- ... 59&vxp=mtr Cheap at $9.95 with free shipping.
deafanddiabetic
Post by deafanddiabetic » Wed Sep 30, 2015 3:09 pm
Wow, that's a great price, stock is never a concern for me.
I'll post what I find out tonight and see what comes next.
1964 CA72
1974 BMW R75/6
1969 CL450
roadrunner
stickey brake switch
Post by roadrunner » Thu Oct 01, 2015 9:55 am
i had the same problem with mine as the guys are saying i gave mine a good cleaning and it works fine.
deafanddiabetic
Post by deafanddiabetic » Thu Oct 01, 2015 11:04 am
A good cleaning did the trick just fine. A spray of carb cleaner and working the plunger back and forth.
Thanks everybody!
1964 CA72
1974 BMW R75/6
1969 CL450
