1964 CA77 Restoration
Steverino
Post by Steverino » Wed Jun 10, 2015 11:22 pm
Yes. I have them installed now. All I had to do was find a large enough bit. And I used my drill press. No worries more than likely they sent you the correct ones. Suppliers try to save the wrong parts for me;).
Steve
Post by Seadog » Fri Jun 19, 2015 5:44 pm
Not much happening right now. I work on small parts every day, like painting the shock covers and polishing bits and pieces while I wait for wheel bearings and seals. Once those are in, I'll start assembly. The gas tank is still at the painter after returning it for flaws. I'll call them next week to see where it stands. Some small parts are trickling in. I'm making a list for a largish order with Ohio Cycle, which I have never done business with before. Mostly nuts and bolts. I'm also searching for a good rear axle to replace the badly rusted one that I have. If I can't find one, I'll just grind the rust and flaking chrome off of mine and paint it.
More as it happens.
Post by Seadog » Mon Jun 29, 2015 8:51 am
Gas tank is back and looking good. Wheel bearings and seals should be delivered today and I'm preparing the front and rear brake panels for shoe installation. I removed the front spacer panel to clear out the old grease and it got me wondering why it fits so tightly - I had to drive it out. Can anyone educate me on why it's a greased part if it can't move? Should it be able to spin?
Anyone recommend a good bearing driver set?
Post by Seadog » Fri Jul 03, 2015 12:45 pm
Started zinc plating today. I chose a small very rusty piece as a test. Unfortunately, I didn't think to take a "before" picture, but I did take a "during" and an "after". Lots more to do and a bigger tank will be needed.
Post by Seadog » Fri Jul 10, 2015 3:30 pm
I've spent days cleaning and zinc plating parts, but have so much more to do. Wheel bearings are installed and I've finished replacing shock seals and oil. I also had to straighten both shafts, which really wasn't too difficult.
sarals
Post by sarals » Fri Jul 17, 2015 2:38 pm
Coming along nicely!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
Post by Seadog » Fri Jul 17, 2015 5:35 pm
Thanks, Sara. I'm plodding along. I've temporarily stopped plating while waiting for a new DC power supply to arrive and other projects have taken over for now.
