Steverino's CB77
Post by G-Man » Fri Jun 12, 2015 1:44 pm
Steve
The Formula for the optimal number of old Honda projects is :-
Optimum number = n + 1
Where 'n' represents th enumber you have now.... :-)
I've used this formula many times and it seems to work for all values of 'n'.....
My upcoming 1962 CB72 started as just a set of crankcases.
Steverino wrote:Thanks Seadog. Old Hondas are addictive I was kind of joking when I said I'd have to build another bike but now I'm already looking for a frame.
S
Steverino
Post by Steverino » Sun Jun 14, 2015 9:37 pm
Then I should consider these two mufflers an excellent start on CB77 number two. Or CB72 number one, depending on which motor follows me home.
Steve
Steverino
Post by Steverino » Wed Jun 17, 2015 10:52 pm
My swing arm tightness issue is bugging me too much. I am going to pull the assembly back off and try to figure out the problem. i am thinking about getting another swing arm to see if that makes the problem goes away. Although, when the rear axle is tightened, the arm swings pretty nicely. I could compress the rear of the arm more and slip the inner seals in place. I don't know...
Post by G-Man » Thu Jun 18, 2015 12:58 am
Steve
I would get another swingarm and compare the two. I think we confirmed your frame was OK so you should be OK going that route.
It would be good to get all the seals in place although I don't think the inner seals actulally take up any space as they fit over the bosses on the frame
Steverino wrote:My swing arm tightness issue is bugging me too much. I am going to pull the assembly back off and try to figure out the problem. i am thinking about getting another swing arm to see if that makes the problem goes away. Although, when the rear axle is tightened, the arm swings pretty nicely. I could compress the rear of the arm more and slip the inner seals in place. I don't know...
Steverino
Post by Steverino » Thu Jun 18, 2015 10:12 am
Thank You for the keen eyes and helpful guidance. I've ordered a set of new seals and I will find another swing arm today. One of the large bike breakers is just three miles from my house. He has several guys dismantling and shipping all day long I'm going to try him first. Maybe I can pick up a frame to go with my extra muffs.
Steve
sixtiescycle
Post by sixtiescycle » Thu Jun 18, 2015 1:10 pm
Steverino wrote:Thank You for the keen eyes and helpful guidance. I've ordered a set of new seals and I will find another swing arm today. One of the large bike breakers is just three miles from my house. He has several guys dismantling and shipping all day long I'm going to try him first. Maybe I can pick up a frame to go with my extra muffs.
Steve
I have one you can borrow for comparison.
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
Steverino
Post by Steverino » Thu Jun 18, 2015 1:17 pm
While looking online for a swing arm I found this nice clean original paint frame. I went ahead and bought it figuring I can use it and the center stand on another project down the road. Now I don't have to worry about what I'm going to do with that extra set of mufflers. I think I am going to leave these bushes alone.
Imagecb77 frame swing arm center stand by Steve Steverinomeister, on Flickr
