To Camshaft or Not to Camshaft....
Post by LOUD MOUSE » Thu May 07, 2015 3:28 pm
What are you looking for?. ............lm
MBellRacing wrote:I wouldn't mind more info on this. Now that I have my other Hawk motor running, wouldn't mind building up something a bit more extreme... or as extreme as 305-350cc will allow.
MBellRacing
Post by MBellRacing » Sun May 10, 2015 9:52 pm
I wouldn't mind a bit more bark up top. I race cars for a living so a peaky cam is what I LIVE FOR! Contemplating doing something crazy like building up a 350cc cammed 5-speed engine for the Superhawk-- just for fun. Basically just live out all the crazy things Bob Guynes told me about in the years I used to hang in his garage.
-Matt
teazer
Post by teazer » Mon May 11, 2015 9:02 am
In that case, there are options:
64mm pistons
reworked head
lightened rockers
light crank
Duplex primary drive
5 speed
Highest compression you can get away with
Highest lift Megacycle cam that they offer.
Heavy duty cam chain
Decent cam chain tensioner arrangement
U 4.4 race gas (drain carbs and tank after each ride)
Crank mounted electronic ignition or self generating system. I have a Todd Henning Motoplat and modified alternator mount that never made it onto my bike - all new and ready to go....
But you also need better forks and frame bracing and a better/braced swingarm
Post by G-Man » Tue May 12, 2015 6:46 am
You could try pushing out to 500cc..... :-)
500cc CB72.jpg (122.63 KiB) Viewed 4553 times
MBellRacing
Post by MBellRacing » Tue May 12, 2015 7:25 am
So I sense some sarcasm, but after watching some videos of people running 500cc CB77s, I am curious what it takes. Same crank?
Post by LOUD MOUSE » Tue May 12, 2015 7:55 am
I know of a feller who uses CB450 crank.
See the gear driven clutch?
Compare piston to bore size!
Notice web added between the cylinders?. ...................lm
MBellRacing wrote:So I sense some sarcasm, but after watching some videos of people running 500cc CB77s, I am curious what it takes. Same crank?
Superchicken
Post by Superchicken » Tue May 12, 2015 8:17 am
That is Killer!!
