1964 CA77 Restoration
I'll answer this in a way which will either bring different ideas or do as HONDA did.
All the actual GASKETS on the engine were installed dry. The only sealant was the Honda Bond between the cases. That's the way HONDA did it and how I've done since 1965. ...............lm
That's good enough for me, LM. I'm not going to reinvent the wheel here. I opened the pump up. Unfortunately, I had to drill the head off of one screw. Inside looks ok to me, but I'm eager for expert opinions.
Thanks! I don't like to throw things away so I am happy to restore parts that others might regard as scrap. That is what interests me. We all have our skills and abilities. You can enjoy these bikes at all levels. I also like to learn from the tricks and tips that people share on this site and others. I saw a great quote the other day - "When you talk you are just repeating things that you already know, but when you listen you may learn new ideas....." G
'61 CB72 '64 CB77 '65 CB160 '66 Matchless 350 '67 CL77 '67 S90 '77 CB400F Yes - the gears are nominally the same diametral pitch (14 DP) but are actually larger diameter and the shaft centres need spacing out. I made a sizing jig so that I could measure the correct running clearance. The non-driven gear is moved down and is larger diameter shaft. The hole for this shaft overlaps the original hole in the casing so there are no holes to fill up in teh case.
