R100
Post
by R100 » Fri Feb 20, 2015 2:24 pm
These are originally meant for wood glue.
At least one of them has a new career as a mini mini grease gun.
- syringe 002.JPG (160.38 KiB) Viewed 2585 times
- syringe 001.JPG (133.17 KiB) Viewed 2585 times
Post
by G-Man » Fri Feb 20, 2015 3:07 pm
Nice job. Every toolkit should have one!
R100
Post
by R100 » Fri Feb 20, 2015 3:24 pm
G-Man wrote:Nice job. Every toolkit should have one!
And they are cheap, which is good because petroleum products will probably attack the rubber over time.
The one with the curved tip has a very small hole. Would work with #90 gear oil, but probably not grease. The one I used for the speedo drive was cut to give it about 1/8" opening.
Post
by G-Man » Fri Feb 20, 2015 3:51 pm
It's always a great feeling making stuff out of things you've already go. My wife was asking where her old frying pan was today. I don't think she really wants it back now......
Hamamatsu Nippon
Post
by Hamamatsu Nippon » Fri Feb 20, 2015 7:15 pm
Oh yeah, it will work with grease. Here I'm getting grease to the bearing by slipping under the cover with a large bore needle attached. You have to press really hard, but it works great.
- RD 012.jpg (153.33 KiB) Viewed 2541 times
1967 CA78
1965 CM90
Soichiro Honda
R100
Post
by R100 » Fri Feb 20, 2015 7:39 pm
Hamamatsu Nippon wrote:Oh yeah, it will work with grease. Here I'm getting grease to the bearing by slipping under the cover with a large bore needle attached. You have to press really hard, but it works great.
That's awesome!
Like you are vaccinating a bearing against the deadly virus - corrosion.
Snakeoil
Post
by Snakeoil » Mon Mar 16, 2015 10:20 pm
You can buy really large ones in farm stores like TSC. They are great for accurately filling forks with zero spillage. Also work great for removing oil.
I use a smaller one to fill bike batteries with distiller water.
Regards,
Rob
