cb77 clutch cable "joint"
klp
Post by klp » Tue Jan 13, 2015 5:42 pm
That's what the fiche calls it - the junction where the cable threads into the right side case.
Has anyone got one?
OldScrambler
Post by OldScrambler » Sun Feb 08, 2015 4:48 pm
Early models are at a 90-degree angle to the case..............later models are at about 75 or 80-degrees to the case. Which do you need..........then I will look in my parts stash..........likely have one or more of each.
ahenthus
Post by ahenthus » Sun Feb 08, 2015 9:08 pm
OldScrambler wrote:Early models are at a 90-degree angle to the case..............later models are at about 75 or 80-degrees to the case. Which do you need..........then I will look in my parts stash..........likely have one or more of each.
OldScrambler, Welcome to the forum. I need a 66 scrambler clutch joint too. Mine is slightly less than 90 deg, looks close to 86-88 deg. i.e. the clutch cable enters the case almost perpendicularly. Please advise.
CLaude
66 CL77
OldScrambler
Post by OldScrambler » Mon Feb 09, 2015 10:21 am
I'll start digging................
OldScrambler
Post by OldScrambler » Tue Feb 24, 2015 2:01 pm
OK............I work REAL slow when its REAL cold............so when it warmed into the 20s today I dug up a few clutch cables with the 'joint' attached. Only one unit (far right) was found that is nearly 90-degrees and it has a partially broken 'wing' that slips beneath the case. It will work as-is (but not recommended for extended use) or could be repaired........The other units have the somewhat sloped angle and are thought to provide less stress to operate. If you or anyone else is interested in any of the 'joints' $20 shipped to the lower 48 from Wisconsin.
ahenthus
Post by ahenthus » Tue Feb 24, 2015 11:46 pm
Man, when you say you'll be digging you really do dig. That's quite an impressive tangle of clutch joints & cables. PM sent.
66 CL77
ahenthus
Post by ahenthus » Sat Feb 28, 2015 12:04 am
Hello, anybody home? OldScrambler, I pm'd you and also left the post before this. Please check your messages.
Thanks,
Claude
66 CL77
