Super Slow 65 CB77 Restoration commences
jugger18
Post by jugger18 » Wed Nov 26, 2014 10:08 am
Pulling the cam cover is a no go as at least one of the bolts is directly under the fram tube and cannot come off. Sprayed more PB, Heat, hammered, has not budged a mm. I am going to keep filling the exposed area of the boltin the cam cover and keep trying.
Removing spokes, Can i just use a flathead on the nut on the portion inside the rim?
Hahnda
Post by Hahnda » Wed Nov 26, 2014 10:23 am
jugger18 wrote: Removing spokes, Can i just use a flathead on the nut on the portion inside the rim?
You can but many times I find them to tight to use a screwdriver at first. I usually use a spoke wrench to loosen and then a power screwdriver. You will need a spoke wrench to tighten them.
So why are the spokes coming out?
jugger18
Post by jugger18 » Wed Nov 26, 2014 10:46 am
I want to polish up the hubs, zinc plate the spokes, and will most likely need to rechrome the wheels.
jugger18
What size are the spoke nipples?
Post by G-Man » Wed Nov 26, 2014 12:55 pm
Thread or flat?
jugger18
Post by jugger18 » Wed Nov 26, 2014 12:57 pm
From the search I finally found reference to them being 5.6mm, so ordered a spoke wrench that does 6 sizes including 5.6mm
Post by G-Man » Wed Nov 26, 2014 1:27 pm
Good plan. Sometimes the correct size is too tight.
