front suspension
lrutt
Post by lrutt » Wed Sep 10, 2014 11:25 am
I don't think the problem is spring rate, it's total lack of dampening. At least on mine. You can make is stiff as hell but it will still bounce without any dampening.
OldStan
Post by OldStan » Wed Sep 10, 2014 2:34 pm
lrutt wrote:I don't think the problem is spring rate, it's total lack of dampening. At least on mine. You can make is stiff as hell but it will still bounce without any dampening.
I agree, that is most likely the problem. I removed the springs on mine to check the shocks when I had the bike apart, mine were good and they don't bounce. I weight about 210. Spacers would make for a stiffer suspension and possibly reduce bounce because of that. If you do decide to put in spacers, that's a good time to check the shocks, then at least you'll know where you stand.
63 CA78
rrietman
Post by rrietman » Wed Sep 10, 2014 11:00 pm
well , yes it is the dampening that is the trouble. just had a hope that stiffing the springs might help. I know it won't, but I'm grasping at straws.
Randy
elephant
Suspension
Post by elephant » Tue Sep 16, 2014 9:52 pm
The spacer modification does not give you modern suspension, but it did help me win the AMA Mid-Ohio Vintage MotoX this year (my age class) on a 1963 Dream......
