cl77 '66 oil leak
jccgolfer
cl77 '66 oil leak
Post by jccgolfer » Fri Feb 07, 2014 10:19 am
Good morning, Just discovered a small oil leak dripping from the bottom of the round inspection cover of the left engine case cover. I've tightened the screws to the point of thinking one will break. Any suggestions? Was there a rubber gasket on the inspection cover? I can't remember. Thanks Jay
Re: cl77 '66 oil leak
Post by LOUD MOUSE » Fri Feb 07, 2014 11:40 am
If you mean the OIL FILTER cover there are 2 "O" rings. .......lm
jccgolfer wrote:Good morning, Just discovered a small oil leak dripping from the bottom of the round inspection cover of the left engine case cover. I've tightened the screws to the point of thinking one will break. Any suggestions? Was there a rubber gasket on the inspection cover? I can't remember. Thanks Jay
Post by G-Man » Fri Feb 07, 2014 11:47 am
LM is spot on - see items 3 & 4
left side cover.jpg (147.73 KiB) Viewed 1952 times
