sarals
Post by sarals » Fri Aug 16, 2013 11:02 pm
I thought I'd mount the Podtronics behind the right side air cleaner element. While the idea is good, it won't clear the side cover. I'll have to fashion a bracket of some sort to mount it on. I'd like to use the original rectifier mount tangs. I don't want to drill ANY holes, anywhere. I want to keep the bike as stock as possible in appearance. I've been perusing the site and I've seen some very clever ideas. I'll think them over and see what my girl brain can come up with.
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
sarals
Post by sarals » Sat Aug 17, 2013 9:58 am
It seems like a piece of aluminum sheet is the way to go. Now to figure out where to put it where it can get airflow and has some room.
Wiring it in is simple enough. The pink and yellow wires from the dynamo are combined and connected to one of the yellow wires on the Pod, the other yellow wire gets the brown wire from the dynamo. The Pod's red wire goes to the red wire connected to the ignition combination switch (the one that was originally connected to the rectifier), and the Pod's black wire is connected to ground.
As I understand it, regulation with the original rectifier was accomplished with a switch in the lighting circuit. That is where the pink wire went. That section is no longer needed, so it will be left disconnected. I read where some folks installed a relay in the lighting circuit. That's a nice touch, but I think I'll not do that.
When I get this part of the circuit modified, I'll get after the electronic ignition. I want to get all the wiring done, tested and then tidied up before I attach any more structural or ancillary pieces to the Old Girl.
1989 NT650 Hawk GT
sarals
Post by sarals » Sat Aug 17, 2013 11:27 am
Here's the circuit with the Podtronics incorporated and stock rectifier removed. Excuse my chicken scratching!
1989 NT650 Hawk GT
Vince Lupo
Post by Vince Lupo » Sat Aug 17, 2013 6:35 pm
With respect to mounting of the regulator, could you possibly velcro it to the front or backside of the toolbox? Or (if you're willing and it will fit there), can you drill a hole into the side of the toolbox and bolt it there?
sarals
Post by sarals » Sat Aug 17, 2013 6:58 pm
Hi Vince! I've considered velcroing it either to the toolbox or the rear fender. There is room to do that. I'm looking for a more permanent mount, but I would like to avoid drilling holes in anything. I really think there is an answer with the rectifier mount, I just have to figure out what it is.
1989 NT650 Hawk GT
sarals
Post by sarals » Sun Aug 18, 2013 11:41 am
Vince, there isn't room on or around the toolbox to mount the Podtronics. There is on the rear fender, and if the location I've chosen in the photo below doesn't work, I'll velcro it there.
I'm going to make a bracket to bridge the rectifier mount and attach the Pod to it. That will leave about a 1/2 inch between it and the battery. That should be good for airflow.
1989 NT650 Hawk GT
malcolmgb
Post by malcolmgb » Sun Aug 18, 2013 3:35 pm
Shouldn't the unit be bolted to something to aid the heatsink? Velcro will not do that.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
