snapped clutch adjust bolt
nation
Post by nation » Sun Jun 16, 2013 2:36 pm
was tightening bolt after adjusting round clutch adjusting screw. bolt just spins and can come out. any suggestions on how to fix? Jim
`66 Honda dream
mike in idaho
Post by mike in idaho » Sun Jun 16, 2013 3:26 pm
You can replace the piece that the bolt screws into, or run a 1/4X20 tap through it and use 1/4 inch course thread allen head thread bolt in it.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
mike in idaho
Post by mike in idaho » Sun Jun 16, 2013 3:27 pm
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
cadman
Post by cadman » Sun Jun 16, 2013 3:30 pm
That bolt goes to the "fork" that holds the adjustment in place. Just remove the right hand engine cover (fairly easy) and you should be able to remove the broken piece of the bolt and use a new bolt (If you can find a JIS bolt). I have purchased standard metric taps and generally will retap a hole for standard (ISO). The two are very close and it seems to work okay.
Post by LOUD MOUSE » Mon Jun 17, 2013 9:14 pm
I think that is a ISO bolt. ...............lm
cadman wrote:That bolt goes to the "fork" that holds the adjustment in place. Just remove the right hand engine cover (fairly easy) and you should be able to remove the broken piece of the bolt and use a new bolt (If you can find a JIS bolt). I have purchased standard metric taps and generally will retap a hole for standard (ISO). The two are very close and it seems to work okay.
russ
stripped bolt
Post by russ » Tue Dec 24, 2013 11:14 pm
mine broke into 3 pieces when I tightened bolt.didn't know threads were already stretched , I think it had been over tightened before. I fabed a new clamp out of a 15/16 wrench . had to heat it and beat it, then grind it and shape a little, and finally tap 1/4 by 20 threads for new bolt. I also cooled in oil after heat-n-beat. didn't want to search just want to ride.
