Helping a friend with his 1964 305 Dream
bluej58
Post by bluej58 » Sat Mar 23, 2013 8:20 pm
Thank you Hahnda,
Those are good tire choices and fair prices to boot.
WHonda
Post by WHonda » Tue Mar 26, 2013 8:49 am
That's a good looking tire WHonda ,the bike too, what size are they and did you get them through J& P ?
I can't find 3.25 or 3.50 on their site
I got the Heidenau's tires (3.5x16) from 'Hahnda', the tubes (3.25-3.5x16) I got from J&P. I already took em for a test drive and they seem fine.
The tires are rated at 400+ lbs and a 93 mph speed.
bluej58
Post by bluej58 » Wed Mar 27, 2013 6:30 pm
Cool WHonda glad you like them, thanks for the review.
Not much done on the bike this week , still checking out suppliers.
It a piers that finding the right battery is going to be my biggest supply challenge so far.
JD
piperjak
Post by piperjak » Wed Mar 27, 2013 7:49 pm
bluej58 wrote:Cool WHonda glad you like them, thanks for the review.
JD
Check out the Motobatt MB9U... fit perfect in my 1967 and no worries about corrosion. It was way under $100
bluej58
Post by bluej58 » Wed Apr 17, 2013 9:08 am
Thanks piperjak but unfortunately I have to get the older style battery that is much thinner.
I think that I can find most of what I need here http://www.ohiocycle.com/ but they want me to give them both the engine and frame numbers to get started.
I have been using the search here and reading a lot of posts but all I came up with is "look on the frame by the steering column", not there.
And "look by the center stand pivot on the left side", if it is there I can't see it, is it under the battery box, how big are the numbers ?
Can someone please tell me where to find a picture or a good description as to where I can find the frame numbers for a 64 CA77 with an engine number CA77-100276
Thank you,
JD
bluej58
Post by bluej58 » Wed Apr 17, 2013 9:55 am
OK , I decided the best thing to do was call Ohio Cycle and ask them.
The Gentleman I talked to told me it is in fact behind the engine above the center stand on the left side , get a flash light and a oil rag.
Of all the crazy places to put a number, there it was !
Here's a pic.
bluej58
Post by bluej58 » Thu May 23, 2013 8:46 pm
I finally got a couple of projects out of the way and was able to spend some quality time with the Dream.
After seeing what a great job Pine-sol did on cleaning the petcock I decided to take apart the carb. and dip it too.
After about 4 hours I rinsed it off and after drying it I sprayed it down with seafoam and let it sit for a day, it came super clean, even the brass parts.
Today I cleaned off the seafoam with regular carb cleaner and put it back together .
I never started a Honda dream before so going by the owners manual,
Turn key to 1, choke on, open throttle, kick twice
turn key to 4 , open choke 1/4, hold throttle 1/8 and start kicking
She fired right up after 4 kicks, this thing hasn't ran since 1984 and it sounds great.
Sometimes things go right , next thing to do is to take a very careful ride up the road on 30+ year old tires to check out the brakes.
JD
