Podtronics rectifier/regulator for CB77
Hahnda
Post by Hahnda » Wed Apr 10, 2013 8:30 am
Post by davomoto » Thu Apr 11, 2013 9:53 pm
Looks like a good cheap alternative!
billyfly1
Post by billyfly1 » Wed Apr 17, 2013 10:42 am
anybody use the Kohler 25-755-03 rec/reg in place of radio shack rectifier? thanx billy
billyfly1
Post by billyfly1 » Thu Apr 18, 2013 5:04 pm
finally have charging squared away! thanx for the great info in this forum
and i'm done!!!
Cheburashka
Kohler regulator--does that wiring work?
Post by Cheburashka » Wed May 01, 2013 8:29 am
Billyfly--I see you have it wired brown/yellow/red. Have you checked to see what kind of voltage that gives you at the battery? Does it function as it should?
billyfly1
Post by billyfly1 » Wed May 01, 2013 8:46 am
It does work... About 1 amp back to battery
I have since switched from ballistic battery
To Mercedes back up battery... Much better
Cheburashka
Post by Cheburashka » Wed May 01, 2013 10:14 am
Thanks. Looking at the wiring diagrams for the Honda and the Kohler, that makes sense.
I'm using a NOS battery. I hope this prolongs its life. At $100 a pop, I can't afford to replace it every season.
