sarals
Post by sarals » Wed Aug 01, 2012 9:58 am
Solomoriah wrote:Hmm. Your original posted pictures show 18182 miles on the odometer; my Dream has over 19,000 miles. So I suppose I'm looking at some transmission work as well...
I was told with the mileage on my bike to EXPECT wear in the transmission. Specifically, that bushing and the kick start pawl. I haven't removed the pawl yet, but the bushing (initially looking good), after measuring, is worn out! If my bike is any indication, while you have your bike apart, it's only about an hour more work to split the cases. I'd not hesitate to do it!
Jensey, I just "eyeballed", I haven't measured anything (except the bushing, at HT's behest). I'd read quite about about wear areas in the gearbox, and none were immediately obvious. The bike always shifted well, and that caused me to relax a little bit when I was inspecting the gears. You're totally right, the oil sure makes things look shiny. Well, that new trans is going in the cases. Period!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
sarals
Post by sarals » Wed Aug 01, 2012 12:39 pm
Is there any difference between the CA77 and CB77 rotor/starter clutch assemblies? I know the CL77 is different - no starter clutch.
1989 NT650 Hawk GT
Post by LOUD MOUSE » Wed Aug 01, 2012 2:00 pm
They are the same. .........lm
sarals wrote:Is there any difference between the CA77 and CB77 rotor/starter clutch assemblies? I know the CL77 is different - no starter clutch.
sarals
Post by sarals » Wed Aug 01, 2012 3:18 pm
LOUD MOUSE wrote:They are the same. .........lm
Thank you, LM!!!!
1989 NT650 Hawk GT
jugger18
Dented tank
Post by jugger18 » Wed Aug 08, 2012 12:32 pm
Any thoughts on attempting to pop the dent by filling most of the way with water, capping it, popping it in the freezer and periodically checking to see of the expanding water/ice pops the dent. I have seen this done with exhaust dents
Re: Dented tank
Post by LOUD MOUSE » Wed Aug 08, 2012 1:29 pm
Might work if you can find some directional ice. .......lm
jugger18 wrote:Any thoughts on attempting to pop the dent by filling most of the way with water, capping it, popping it in the freezer and periodically checking to see of the expanding water/ice pops the dent. I have seen this done with exhaust dents
Solomoriah
Post by Solomoriah » Wed Aug 08, 2012 8:13 pm
sarals wrote:Specifically, that bushing and the kick start pawl. I haven't removed the pawl yet, but the bushing (initially looking good), after measuring, is worn out! If my bike is any indication, while you have your bike apart, it's only about an hour more work to split the cases. I'd not hesitate to do it!
I'm resigned to the fact that I'll have to split the cases at this point. How will I know if the kickstart pawl is worn out, though?
