CA77 condenser
joseph22
CA77 condenser
Post by joseph22 » Sat Jul 14, 2012 11:33 am
ANyone know if there is an easy way to remove and replace the condenser on a Dream CA77???? I located it but can not image how to remove it without disassembly of the motor from the frame.. Must be a better way . regards all jcs.services@yahoo.com Thanks
conbs
Removing condensor
Post by conbs » Sat Jul 14, 2012 1:12 pm
Jo, search this site. I remember reading a couple posts a while back. Seemed like one guy bent a wrench so it would reach the bolts and turned them 1/6 turn at a time.
Are you absolutley certain your condensor is bad? It probably shouldn't be the first place to look.
joseph22
condenser CA77
Post by joseph22 » Tue Jul 17, 2012 1:04 pm
Thganks for the reply . I am not sure the condenser needs to be replaced but as I was changing the points I thought I would change the condenser, until I discovered its location..!! There are two phillips head screws holding the condenser tothe top of the motor. However it is tucked away under the frame just behind the horn..
Clearly it was not meant to be replaced.. Any help would be appreciated.
Thanks JoeC
See photographs
condenser location under frame CA77E Dream on Honda
joseph22
photo condenser location CA77
Post by joseph22 » Tue Jul 17, 2012 1:07 pm
rzgkane
Re: CA77 condenser
Post by rzgkane » Tue Jul 17, 2012 5:29 pm
I would only replace it if I had to. And if I had to, I would probably just leave that one where it sits and mount a new one someplace else!
joseph22 wrote:ANyone know if there is an easy way to remove and replace the condenser on a Dream CA77???? I located it but can not image how to remove it without disassembly of the motor from the frame.. Must be a better way . regards all jcs.services@yahoo.com Thanks
1965 CA77Dream
