Post by LOUD MOUSE » Wed Jul 11, 2012 2:30 pm
I was waiting for someone to mention the piston aluminum in that barrel.
A trick used to remove it from a 2 stroke barrel is to use pool acid and rinse quickly.
It removes the aluminum and when rinsed quickly doesn't harm the barrel.
Use rubber gloves for sure. . .............lm
jensey wrote:Hi,
Why do you think deep grooves should be seen with a seizure ? I certainly see evidence of a seizure in multiple spots, but it's hard to tell if this is a full seizure caused by oil / heat issue's or by humidity / fuel issue's (water / fuel in the oil). For sure a re bore required,
Please make some pictures of the piston belonging to this cylinder,
jensey
Post by jensey » Wed Jul 11, 2012 3:01 pm
Well, I'm sorry to let you wait so long.
The reason why suggest a re bore isn't the aluminium in the barrel, but the complete absence of the hone structure in the cylinder ( and meanwhile remove the aluminium in the barrel).
As you know the hone structure keeps the oil between the piston and barrel, and when there isn't any hone structure, the piston will seize, eventually helped by moisture or fuel in the oil .
Considering the mileage this was meant to happen,
sarals
Post by sarals » Wed Jul 11, 2012 3:18 pm
Jensey and Ed. Here are some photos of the seized piston. I took one of the "good" piston, as well. I'll be on the way to a machine shop shortly, with the barrel and the pistons (in case they want to see them). I was hoping to get away with just a hone, but if not - then that's the way it is. It HAS to be right!
And the good one:
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
sarals
Post by sarals » Wed Jul 11, 2012 3:23 pm
Also, I don't expect to see grooves with a seizure. I did expect to see some damage to the liner because of the broken rings. More to my point, "caused" by a broken ring (a gouge, for instance). I've seen seized two stroke barrels, and they look pretty much like this one. Transfer of metal and money to be spent. Joy.
Ed, thanks for the tip on the acid. I had heard that battery acid could be used, too. I'm going to let the machinist do his magic, and then ask him "how did you do that"? ;~)
Thank you, guys!
~~Sara
1989 NT650 Hawk GT
cknight
Post by cknight » Wed Jul 11, 2012 3:27 pm
LOUD MOUSE wrote:I was waiting for someone to mention the piston aluminum in that barrel.
jensey wrote:Hi,
Easy-Off oven cleaner will also remove the aluminum from the cylinder. Just don't get it on any aluminum that you want to preserve. Regards, Chase
sarals
Post by sarals » Wed Jul 11, 2012 4:35 pm
Chase, thanks! That's a great tip.
I just returned from the machinist. He's going to measure the bores, look at them closely, and tell me what I need to do. I left him the old pistons, he wanted to look at them, too. He's also going to clean the barrel for me, and upon asking - yes, he can "do" the head, too. The valves, cut the seats, etc. Wooo-hooo!!
I took a picture of the combustion chamber of the cylinder that had the seizure. I'm not at all well versed, but I had said (and so did Ed) that it was running hot. Here's another shot. There may be more clues here.
1989 NT650 Hawk GT
Post by LOUD MOUSE » Wed Jul 11, 2012 4:44 pm
This pic and the top of the piston told me it ran HOT.
Call me. .....................lm
quote="sarals"]Chase, thanks! That's a great tip.
Image[/quote]
