63 honda 305, low and terrible voltage
Here you go. All you ever wanted to know about rectifiers but were afraid to ask.
http://en.wikipedia.org/wiki/Rectifier regards, Rob Here it is....
http://www.radioshack.com/product/index ... Id=2062584 66 dream, 78 cb750k, 02fz1, 09 wing
LM: I interpret your question as, "Is an SCR a full wave rectifier?"
The answer is no. It is a single diode (but controllable), so it can only serve as a half-wave rectifier. You could use 2 SCR's to make a full wave rectifier in the same way that you can use 2 of any diode type for full wave rectification. You could use 4 SCR's in a 'bridge' configuration (that familiar diamond or square combination of 4 diodes) to achieve full wave rectification. bloodweiser: The terms 'full wave' and 'bridge' are not the same. Full wave means that both the negative and positive halves of the AC signal are being rectified. Bridge refers to the use of 4 diodes wired a certain way so as to achieve full wave rectification. Wilf
A low and terrible update:
New battery. Started perfectly and ran great for 20 minutes, until it didn't. No power at the side of the road, horn, lights, nothing. Found my battery bubbling, warped and hissing, and had it quickly disconnected. Battery currently reads 11.5v though I'm hesitant to try and use it again. I'm hoping this is a simple dead original rectifier causing overcharging, but am open to other interpretations. I have yet to hook up a new, or different battery to see if what happens. Any other possible damage from this incident? --------
'63 Dream '68 CT90 (x2) '76 RD400 '06 Xl1200R
