I am in a bit of a pickle with rocker arm reassembly on my 65 CA77.
When putting the pins back in I found there are two different sizes (and that I had accidentally gotten two mixed up).
I am now concerned that I may have swapped the rocker arms too (since I packed these parts as sets).
Are the rocker arms different from one another and if so how can you tell which are which?
Any help is greatly appreciated.
Kevin.
Rocker Arm Pickle
Re: Rocker Arm PickleAs long as there is no excessive wear to the cams or rockers ya can install them in any location.
The shafts are no problem as long as the same is true and ya put the ones with the small oil holes at the intake side and the ones with the larger hole at the exhaust side. .........lm
