Jlovvorn
Post
by Jlovvorn » Thu Jan 12, 2012 5:51 pm
The adjusters on the lever and the case are all the way in.
I am thinking the PO used the wrong cable or rerouted it wrong.
The cable comes out of the lever and takes a sharp down turn and goes under the tank on the same side as the lever and then down to the box.
That seems like too quick a turn. And could be the problem.
If I routed the front brake cable like that, it would lock up the brake every time I turned the bike.
Shouldn't the route be across the tree and down on the side opposite the lever? Ie, the same side as the case mounting?
mobilyte
Post
by mobilyte » Thu Jan 12, 2012 5:56 pm
Jlovvorn
Post
by Jlovvorn » Thu Jan 12, 2012 6:10 pm
Thanks for the reminder.
Tried a search and didn't find the answer.
Might have missed it.
But this isn't it.
mobilyte
Post
by mobilyte » Thu Jan 12, 2012 6:57 pm
assuming you have the correct length cables, those photos do a good job of showing where the cables should be routed.
Jlovvorn
Post
by Jlovvorn » Thu Jan 12, 2012 7:15 pm
Ok, perhaps I am am missing what your seeing, but I don't see a single picture of the clutch cable in those photos.
I am going to try and upload a photo here, in case it sheds any light.
Thanks everyone for the help so far.
Jlovvorn
Post
by Jlovvorn » Thu Jan 12, 2012 7:18 pm
Two of two
Post
by LOUD MOUSE » Thu Jan 12, 2012 7:22 pm
Do ya turn that big cast part?. ...lm
Jlovvorn wrote:Ok, perhaps I am am missing what your seeing, but I don't see a single picture of the clutch cable in those photos.
