New wheel bearings
clhiller
New wheel bearings
Post by clhiller » Wed Aug 31, 2011 10:47 pm
I am replacing the front and rear wheel bearings on my '66 CB77. Can I use sealed bearings or stay with the shielded type?
Post by davomoto » Thu Sep 01, 2011 12:35 pm
I like the sealed, so I can add grease when new, you'd be surprised how little is in new bearings, and repack them when I have the wheels off!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by LOUD MOUSE » Thu Sep 01, 2011 7:25 pm
Did ya mean SHIELD?. ........................lm
davomoto wrote:I like the sealed, so I can add grease when new, you'd be surprised how little is in new bearings, and repack them when I have the wheels off!
Davo
Post by davomoto » Thu Sep 01, 2011 7:28 pm
I think of shielded as the metal covers, and sealed as the rubber covers. The rubber covers are easy to remove and reinstall to grease the bearings.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Post by LOUD MOUSE » Thu Sep 01, 2011 7:39 pm
OK!!!!!!!!!!!. .................lm
davomoto wrote:I think of shielded as the metal covers, and sealed as the rubber covers. The rubber covers are easy to remove and reinstall to grease the bearings.
Davo
clhiller
Post by clhiller » Fri Sep 02, 2011 8:48 am
I found NTN numbers 6304LLB for the rear and 6302LLB for the fronts. The LLB suffix means a two rubber, no contact seal for increased speed rating over the traditional contact style seals. $8.50 apiece at the local bearing supplier
