What is the average compression reading on 305 Dream?
murray-eliminator
Post by murray-eliminator » Mon Jul 11, 2011 3:58 pm
Mine are reading 90psi on both cylinders after warm up. seems low to me?. but it runs great.
brewsky
Post by brewsky » Mon Jul 11, 2011 5:38 pm
90 is usually the minimum given for most engines to be able to run.
Did you remember to open the choke and throttle when you did the test?
My CA77 reads 149 hot.
If yours runs great, then chances are there is an error in measurement of the compression.
ie....seal in the plug hole, leak in the tester itself, not holding the throttle wide open during the test, dirty air cleaner etc.
murray-eliminator
Post by murray-eliminator » Mon Jul 11, 2011 5:49 pm
Ok I did not open up the throttle when i tested it, will retest. Thanks.
murray-eliminator
Post by murray-eliminator » Mon Jul 11, 2011 6:23 pm
OK Re tested with throttle wide open & getting 130psi now. that makes me feel better..is that suitible for a original engine that has not been rebuilt?
brewsky
Post by brewsky » Mon Jul 11, 2011 7:11 pm
Yep....should be good to go with that number
