Dana's updates
FAST FRED
90118-268-000
Post by FAST FRED » Sun Apr 17, 2011 9:57 pm
Dana, I'm sure it's going to be 90118-268-000. It matches your discribtion exactly. It screws into the bottom of the steering stem and anchors the steering dampner.
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
Dana01
Post by Dana01 » Sun Apr 17, 2011 10:34 pm
I dunno Fred. I looked under the damper and on the blow-up and can't find it.
What do you think?
Dana
1966/7 CB-77 Red of course
Hoosier Tom
Post by Hoosier Tom » Sun Apr 17, 2011 10:57 pm
Dana,
The photo is one of my steering stems and shows where the pin goes.
HT
Dana01
Post by Dana01 » Mon Apr 18, 2011 12:19 am
Tom & Fred,
TYTYTYTYTY!!!!
The picture actually solves another mystery I had.
Fred wins lunch on me :)
Dana
Dana01
Post by Dana01 » Sat Apr 23, 2011 3:18 am
Got new bars from JC Whitney. Decent enough for the price. Got the cheap set ... came w/o holes but easy enough to drill on my drill press. Also didn't have the "doubler" on the center section or the knurls for the clamps. Measurements close enough to the stockers. I can post if anyone wants. Cables should all fit.
Installed bars, both hand assemblies, mirror stanchions and mirrors (Asian rectangulars), new rear brake cable, front brake cable, new battery (had to trim my bridge rectifier mounting plate a tad. Mounted left pipe, removed the impossible remains of right header. Will install new header next week.
Remaining:
front sprocket (Sprocket Specialists 15t still on back order ... grrrr), which is holding up right case cover, clutch cable, kicker
waiting on Asian seat
no chain guard yet ... decision needs to be made whether or not to run with/without
LED tail light and last bit of tail wiring
15-20 loose items on punch list (grease nipples, cotter pins, oil and gas, misc wire connections, etc)
Off for the weekend to sample the grapes of Napa so no work till next week. I'm hoping for a firing by next weekend. Fingers crossed. PO had left cylinder way rich ... float level was off by a lot. Tons of crud in the ex. port and pipe.
I'll wait till done to post final pics :)
Dana
Dana01
SHE LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by Dana01 » Sat Apr 30, 2011 6:45 pm
Did a partial Ed tuneup, made new hot/ground battery cables ... then I just couldn't contain myself any longer ... so I gave it a try as is. At first bike wouldn't start at full choke except for some sputters and a nasty starter chain back rattle or two (I think it's too loose and needs replacement). Horn and LED tail light worked ok so I decided to try with no choke.
Started right up and rev'd nicely. Idled at 900-ish. Exhaust smells good with a teeny-tiny bit 'O richness to it. Bridge rectifier didn't get hot at all. Let it idle for 10 minutes or so keeping an eye on oil/fuel leaks and heat.
I did set the points correctly, the throttle pulls and slides, but still need to do the timing, air screw, etc.
Also, the exhaust pressure feels weak on the right side. Didn't check plugs because I was too busy smiling and whooping it up. Tiny oil leak at a head acorn ... all fixed. No headlight and I still have a dozen or so on the punch list. Still waiting for sprocket, seat, chain guard, and mud flap to arrive (can't drive w/o a mud flap).
BTW .. it dawned on me I had no clue as to the meaning of the 3-position key switch. I just haven't payed attention on the forum :0
Not worth taping a video of just a startup, but I will do one when I ride her. Of course pics when complete.
Dana
geosar
Post by geosar » Sat Apr 30, 2011 7:09 pm
It is quite an amazing feeling when the engine starts after a long absence of working. I was actually shocked when mine started a few weeks ago.
Congratulations.
Still love the color. I feel my 1965 CL77 will look very similar to yours.....some day.
George
Arizona
