1962 CB77 Restoration underway
Hoosier Tom
Post by Hoosier Tom » Sun Mar 06, 2011 11:01 pm
Slide the set ring on the main shaft and set the cotters in their groove. Slide the 23T 3rd gear counter shaft on and place the set ring.
Hoosier Tom
Post by Hoosier Tom » Sun Mar 06, 2011 11:08 pm
Put the other gears on and you should have something like this.
rmcrump1
Post by rmcrump1 » Mon Mar 07, 2011 10:39 am
Hoosier Tom wrote:Now you can pull the gearshift spindle assy straight out. You can see the shift drum stopper assy. Remove the kick start stopper bolt (17mm socket head) and the 2 bolts and remove the assy.
Tom;
Are you saying that the shift shaft assembly can be replaced without splitting the cases? I recently acquired a 65 CL77 and some previous owner had cut part of the splined end of the shaft off. I thought about replacing it but didn't want to split the cases. If it can be done by just pulling the clutch side off the engine that is wonderful.
Hoosier Tom
Post by Hoosier Tom » Mon Mar 07, 2011 12:28 pm
rmcrump1 wrote:Are you saying that the shift shaft assembly can be replaced without splitting the cases? I recently acquired a 65 CL77 and some previous owner had cut part of the splined end of the shaft off. I thought about replacing it but didn't want to split the cases. If it can be done by just pulling the clutch side off the engine that is wonderful.
Yes, If you are talking about the shaft that your shift pedal attached to it can be replaced without splitting the cases.
HT
rmcrump1
Post by rmcrump1 » Mon Mar 07, 2011 12:30 pm
That is great. Thanks for the reply.
Richard
Hoosier Tom
Post by Hoosier Tom » Mon Mar 14, 2011 11:21 am
After soda blasting and washing my cases, I started to get the trans back in. First I put my shift drum oil seal in then put the forks in and slid the drum down and through the forks. Install your shift fork guide pins and rollers in the orientation I showed previously along with your lock washer. Check to make sure your shift forks travel smoothly in the drum. Fold the lock tabs up to the sides of the hex top 9in the photo I have not done that yet).
Hoosier Tom
Post by Hoosier Tom » Mon Mar 14, 2011 1:17 pm
I next put in the trans. First put in the main shaft assy, lining up the fork with its gear and the bearings with their set rings. Next put in the counter shaft assy making sure to line up your bushings with the dowels. Don't let your bushing slide too much or you risk dumping your roller bearings.
