dissasembly of rear shock coversHi Dana
I built this with several different end fittings so that I can dismantle different types of shocks. If you are only doing Dream shocks the bottom part of the compressor can be much simpler. G '60 C77 '60 C72 '62 C72 Dream '63 CL72
'61 CB72 '64 CB77 '65 CB160 '66 Matchless 350 '67 CL77 '67 S90 '77 CB400F Yep, it's possible to dismantle Dream shocks completely. You can extract the damper innards and replace seals and oil. The WS Manual says how much oil is required.
The rod, piston and seals are held in place by a threaded retainer ring but are quite a tight fit. I Made an extractor to perform the operation safely. G '60 C77 '60 C72 '62 C72 Dream '63 CL72
