Agreed - What should I use to lube the throttle cable? suggestions?
-Sascha
cyclon36 wrote:It's hard to tell without pipes on, but I think your idle might be a bit high. Have you dropped your sliders down all the way? Also, might want to lube up your throttle cable as good measure. Not sure if that spike in RPM is a sticky throttle cable, slide, or whatever but best to cover all bases.
