Hey Guys,
So I came to a funny realization last night as it relates to the brake light...
So the brake 'running light' is actually when the brake switch is pulled down and the lever activates the 'braking" light when the switch pin moves farther upwards. Is this correct? I realize I have it backwards.
-Sashca
Brake Light Switch
Sascha, I bought that exact spring from Ohio Cycle. If it is the spring you need then it is part#35357-253-000 ($10) or 35357-271-000 ($6.50) depending on your frame vin. If it is the stop switch rod then it is part# 35355-259-000 ($5). I may have the dollar figures with the wrong numbers but they are the correct amounts anyway. Call Nick. Regards, Jeff H.
1964-C77 305 Dream
2002 BMW R1150GS
2002 BMW R1150GS
Not sure how that could happen.Sascha wrote:Guys,
The issue is that whenever I use my foot on the lever, it moves the pin upwards, not downwards... !?
-Sascha
Look at the Main Stand, Step bar diagram in the parts book (pg 68) to see how it should be aligned.
The spring is connected to the rear brake spindle, and the stop switch arm. The switch is connected to the stop switch arm with the stop switch rod.
The rear brake spindle should be aligned at 12:00 position.
