CB77 Head Conversion to CA77 Cylinder / Motor
BLUE62
Post by BLUE62 » Sat Dec 04, 2010 5:45 pm
Has anyone any knowledge / comments on putting a two carb CB77 Head on a CA77 Cylinder / Motor then dropping into a CB77 Frame?
cyclon36
Re: CB77 Head Conversion to CA77 Cylinder / Motor
Post by cyclon36 » Sat Dec 04, 2010 6:04 pm
BLUE62 wrote:Has anyone any knowledge / comments on putting a two carb CB77 Head on a CA77 Cylinder / Motor then dropping into a CB77 Frame?
Just wondering, but if it' going in a CB77 frame, why not a whole CB77 motor?
Post by LOUD MOUSE » Sat Dec 04, 2010 6:18 pm
Other than the gears ya would have a similar engine/bike HONDA issued. ............lm
BLUE62
CB77 HEAD TO CA77 CYLINDER / MOTOR
Post by BLUE62 » Sat Dec 04, 2010 6:25 pm
My concern over the conversion is the CA77 is a 360 degree crank (both pistons up and down at same time) versus the CB77 with opposing 180 degree crank / piston movement. The piston tops may be different, as well as the Cam timing, etc. etc. The CA77 has a different loap and sound that might make the change interesting.
Re: CB77 HEAD TO CA77 CYLINDER / MOTOR
Post by LOUD MOUSE » Sun Dec 05, 2010 8:30 am
<<<<<<<Has anyone any knowledge / comments on putting a two carb CB77 Head on a CA77 Cylinder / Motor then dropping into a CB77 Frame?>>>>>>>>>>>
Ya will need to do cam timing changes and a different points cam.
No problems with the pistons/valves in fact ya will gain compression.
HONDA issued CB bikes with this engine as stock. ..............lm
BLUE62 wrote:My concern over the conversion is the CA77 is a 360 degree crank (both pistons up and down at same time) versus the CB77 with opposing 180 degree crank / piston movement. The piston tops may be different, as well as the Cam timing, etc. etc. The CA77 has a different loap and sound that might make the change interesting.
