Marlin,marlin4622 wrote:side view..
im afraid that the floats are too low...
i am judging by horizon at the base of the carburetor. where the gasket lies. I make that as straight as possible and then look to see if the main jet housing is in view... or am i suppose to judge at the top of the floats??
thanks
Remove the brass jet holder and the bottom (top as viewed in your pic) of the float should be level with the stub of the carb body that it screws in to, with the float tang just touching, but not depressing the float valve piston.
That should make the distance from the gasket surface to the bottom of the float 22.5 mm.
