CA77 wont return to Idle
slopokecr
Post by slopokecr » Mon Nov 01, 2010 8:05 pm
Aloha, all those wiser and more knowledgeable than I.
1967 CA77
Problem has gotten progressively worse--when I roll on the throttle, then back off to shift, RPMs will not come down. I have tried:
1)Lubing cable/throttle/checking for kinks
2)Checked for air leaks at intake/new gaskets
3)Cleaned fuel system/Tank/carb/jets/new fuel lines (I was thinking the E10 fuel they sell here was gunking up my slide)
4)Checked to see that needle is secure in slide
Twisting the throttle with carb off but cable still in place, slide appears to return all the way down. Could my slide return spring be worn out?
Any ideas?
Mahalo, Slo
Post by davomoto » Tue Nov 02, 2010 8:49 am
Slo, try twisting the throttle with the carb bolted to the engine, and see if the slide bottoms out. How do the plugs look? Possibly advance weights sticking, but doubtful.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Hotshoe
Post by Hotshoe » Tue Nov 02, 2010 9:46 am
How about your carb air jet, it can affect idle.
Recommended setting is 1 1/4 - 1 1/2 turns out from bottom.
bonjour
Post by bonjour » Tue Nov 02, 2010 11:19 am
I would say it's an air leak.
Almost without a doubt.
Do you have much power when the RPM 'hangs' ? Is not, air leak.
You can probably also see it by taking a look at the plugs, both, or 1 , is probably white.
Wich indicates that you run lean, by probably an air leak.
Just check the plugs.
Also because you state 'the problem has gone progressively worse'
I always listen of the slides of the carb go back all the way, engine off, twist the trottle, and release, if you can hear a loud 'click' or 'clunk' then you slides are all the way back and rest on the idle screw. ( they 'clicked or clunked' against that)
You might test or ckeck your head gasket for air leaks.
Use a little water and soap, if you see bubble's forming with the engine on, between the cilinders and cilinder head, then ya got a leak there.
FluteTears
Post by FluteTears » Tue Nov 02, 2010 12:02 pm
bonjour wrote:I would say it's an air leak.
One of the things that I used to use for checking vacuum leaks was to spray something at the intake that would not burn and see how the engine would run and then use the same on all the air intake to find a leak. I cant see bubble's forming from an Intake air is being suck in at that point.
Dont use gas LOL
Hair spray used to work but then you have to clean that up.
1974 CT90
1964 CA77
cyclon36
Post by cyclon36 » Tue Nov 02, 2010 12:37 pm
I had a similar problem and it turned out to be something I would have never thought of. If you take the tank off, look at the Y-connection for the throttle cable. One of my sides after the split had popped out of its socket and was causing the cable to pull that side open just a tad.
slopokecr
Post by slopokecr » Tue Nov 02, 2010 1:29 pm
Thankyou Gentlemen for the tips. The people on this forum are a dying breed,,,, the kind that are giving of their time and knowledge. I appreciate it.
Aloha, Slo
