clutch pull to easy
G-GAURD
clutch pull to easy
Post by G-GAURD » Sun Sep 12, 2010 6:05 am
i'm not sure if my clutch is working when i put the side cover on after hooking up the cable there doesnt seem to be any resistence other than the return spring in side the cover the clutch shaft and ball bearing are there they just dont seem to be engaging the clutch.
any suggestions
brewsky
Post by brewsky » Sun Sep 12, 2010 6:16 am
Did you adjust the big screw (adjuster) that goes thru the sidecase?
Post by G-Man » Sun Sep 12, 2010 8:26 am
There is a single ball-bearing inside the lifter mechanism that bears onto the end of the clutch pushrod. That may have fallen out.
uadmlj1
Ball Bearing Location
Post by uadmlj1 » Mon Aug 22, 2011 1:43 pm
I am having similiar symptoms as I just replaced the clutch cable. Where exactly should the bearing be located. Microfiche doesn't show enough detail.
Thanks.
'66 CL77
1966 CL77
