removing rocker arm pins
G-GAURD
Post by G-GAURD » Mon Aug 02, 2010 2:43 am
is there anything i can use to get these pins out if i dont have that special tool? (other than a big hammer) ?
chico
rockers
Post by chico » Mon Aug 02, 2010 5:30 am
the head has to be off block studs, take a big flat bladed screwdriver and get the pins moving in the head then find a screw that fits the thread in end of pin and pull them out.
chico(steve)
66 CB77
ride safe
rustywrench
pins
Post by rustywrench » Mon Aug 02, 2010 8:28 am
You can make your own puller by using a 6mm bolt and a socket that is slightly larger inside diameter than the pin. That will pull it out far enough to get a plier on it for further removal.
RW
Re: removing rocker arm pins
Post by LOUD MOUSE » Mon Aug 02, 2010 8:36 am
As ya look at the Small End ya can use a Long Punch or Rod and knock it out far enough to use the punch/rod to pry them out at the area where the stud passes through.
Quick, simple and no special tools. ..........lm
G-GAURD wrote:is there anything i can use to get these pins out if i dont have that special tool? (other than a big hammer) ?
G-GAURD
6mm worked perfect
Post by G-GAURD » Wed Aug 04, 2010 1:41 am
thanks the bolt and socket worked perfect
houseowax
Post by houseowax » Thu Aug 12, 2010 1:38 pm
FWIW I just used a 6mm bolt, threaded it in about 1/2" then yanked it out with a pair of LeverLocks clamped on the head of the bolt.
'63 CA77 - Giving me all kinds of headaches.
'64 CA77 - Patiently waiting it's turn
'65 CB77 - A 'great winter project'
Post by LOUD MOUSE » Thu Aug 12, 2010 1:52 pm
While ya are just completing the first one I have all of them out. ..........lm
houseowax wrote:FWIW I just used a 6mm bolt, threaded it in about 1/2" then yanked it out with a pair of LeverLocks clamped on the head of the bolt.
