wow, guys thanks for all your advice.
here's my exact intention - when i turn the key to the first position i want everything to work. i do not need the second position to do anything necessarily.
ok, so i am leaving off the dimmer/horn left hand controls for sure if i can do so without causing other things to malfunction. I want the bike to be as minimal as possible. as for the high/low beam, i thought i would install a 3-position toggle (one position off, one high and one low). the high and low positions would also be connected to the speedo indicator lights (brown wire).
i am pretty sure i have the light situation worked out, my only concern is making sure the charging system still functions properly.
sorry if i am a bit confusing, electrical is a learning operation for me but eager to do just that!
thanks again....
ignition switch replacement - 4 into 6 - help?!
crispy,
I think you're now looking at a 3PDT (3 pole, double throw) toggle switch:
- 1 pole to connect the Pink to the Yellow when your headlight is on (either high or low)
- 1 pole to connect the BA (battery) to either the high beam or the low beam filament
- 1 pole to connect the BA to the White (TL) supplying power to the tail light and also the Brown supplying power to the speedo indicator lights whenever the headlight is on
That's a pretty big toggle switch, and I wonder if it defeats your minimalist intentions?
The horn is no big deal because it's only 'in the circuit' when you press the horn button. Do you intend to use the horn? If so, you will need a horn switch.
Wilf
Wilf
- h305 Moderator
Yep; make this pole 1 of the light switch. Nope.Wilf wrote:crispy,
Wilf
To achieve your basic requirement, Crispy:
Ign sw OFF - No connection. Nada.
Ign sw ON - Red connects to Black & Brown (Honda harness) which you join together
Brown to pole 2, 1st terminal of the 'new' light switch; the 2nd terminal goes to the dimmer switch centre contact; hi-beam/lo-beam (R & Bl) remain the same from here
White (already) goes to taillight, so join to here and to meter lamps
Seemples!
Let me know if you need expansion or a diagram posted.
e3steve-
i think you understand what i'm trying to do thank you! i don't think it is as hard as it seems. after all, i am removing stuff, not adding.
i think just to be clear, i will take you up on your offer for the diagram. i just want the toggle to control the headlight/taillight on/off functionality.
just want to make sure you understand i do not have the hand control dimmer installed on the bike. the toggle is replacing that altogether. thanks for your help!!!
Steve,
I think crispy is looking for 1 toggle switch to cover these functions:
-turn the headlight on/off, selecting either hi or lo beam
-turn the tail light and the speedo indicator lights on whenever the headlight is on
-switch in the extra generator coils when the headlight is on
As he says, he doesn't have a dimmer switch and wants the toggle switch to do that job.
I don't know how these requirements can be met with other than a 3PDT switch.
Wilf
Wilf
