eyhonda - 63 cb77 cafe project
- jleewebb
lookin good
looking good, the vintage plate will make bike look extra cool...glad you could make that seat pan work, I knew I was saving that raggedy old piece for something...Lee
'62 CB77. "It's a rider."
Re: hole in case!!??
Ya had it apart so take another good look and check the pic of that area of the parts book. ................lm
eyhonda wrote:I've noticed some small holes in the bottom of the engine case. Can anyone help me identify what goes on underneath? Will oil spray out of that area? I'm planning to repair it with JB Weld. Unless someone has a better suggestion.
- Contact:
It seems just a bad moulding / casting issue, probably opened by blasting or so.
I checked a few cases, and I don't think that oil will flush out there, it's behind the packing area, but you have to check or send us a close-up of that area. This part of the case is used to press the cases from each other, and don't have an other function.
- Contact:
@ LM: I never had the cases apart so I don't know what it looks like inside.
@ Deez: Thanks! I'm glad you like my previous work. I cut my teeth on a 75 cb400f a few years back. All the bikes are gone due to loss of work. But I'll likely keep this Superhawk. Of all the bikes, this is definitely one of my favorites and one of the hardest bikes to find.
@ Jensen: Well, that's good news. That's as close up as I can get. I never blasted it. I just cleaned it with aircraft stripper. I never noticed it before until it was painted. Then it was obvious. Anyway, it looks like no oil is there or meant to go anywhere from there. I can still just cover it with JB weld anyway. It's on the bottom. If it gets oil on it later, it will be harder to repair.
Thanks,
Eric
Thanks,
Eric
63 cb77 cafe
www.eyhonda.com
www.eyhonda.com
hole
I second Jensen's observation. It is a casting cavity with no obvious useful purpose, at least not to me. As long as you are properly sealed around the bolt just forward of it, you won't see any unwanted oil there.
You do have a very nice looking ride there by the way. Rw
- Contact:
cylinder install
Here, I've assembled the motor. Pretty straightforward and no issues. I had Phils Cycle do the valve job. Since I didn't have a valve compressor and I didn't have a good way to do a valve job, I had the shop do it.
63 cb77 cafe
www.eyhonda.com
www.eyhonda.com
