Hi all,
Does Anyone have instructions how to take apart the front shock absorbers On a Honda CB77 (i mean the hydraulic chamber)? how do i separate the active fork from the fixed fork ?
Michael
Restoration Of Front Shock Absorbers
Steel or aluminum sliders? The steels have a threaded on chrome seal holer that a pin wrench, or a belt wrench can be used to unscrew them. They can be a bear, or sometimes they spin off easliy. Once unscrewed, you can seperate the tube from the slider by pushing down on the fork tube, and pulling up in a slide hammer type of motion.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
The perennial question - what oil should I use in my xyz? There are as many opinions out there as there are riders.
We all differ and we are all right (in our own minds at least).
What I use is Fork Oil and in a CB77 I'd use 30wt or 20W if you are light and the roads around you are smooth. 30 is not always easy to find and I usually end up buying a case. It's available on line.
Modern bikes have completely different fork internals and use much thinner oils to work in their smaller orifices.
You could probably get away with motor oil if nothing else was available, but Fork Oil is better IMHO
