Dunstall mufflers
Mike Mullins
Dunstall mufflers
Post by Mike Mullins » Thu Jun 25, 2009 6:37 pm
Thought I'd post pics of the Emgo Dunstall mufflers I just installed. One of our fellow members who has dial up only had asked me to let him know how it went, and I thought it would be much easier for him if I posted the pics here. Perhaps others also. I slipped the mufflers (without the reducers) into place and held them there while marking the new hole location, through the mounting hole, with a sharpie pen ( and I did this more than once just to be safe.) A bracket with 2 bolts in the muffler and which then bolted to the lower, angled muffler mount would be much more desirable. I also found that the right side header was bent slightly (probably as a result of the same incident that bent the original right side muffler slightly.) I re-aligned it in approved Hoosier fashion by bolting the header firmly in place, placing the muffler on the header, and applying a scientifically calculated amount of force to the aforementioned muffler. At any rate, they are on, and sound better than the open headers. Now I can hear the cam chain rattling.
Mike
66 CB 77
76 BMW R75/6
99 GL 1500 trike
75 & 79 XS 650's
CliffC
Post by CliffC » Thu Jun 25, 2009 10:34 pm
Mike,
They look good and looks like you got everything lined up on the installation. If you could cut off, looks like the last 1 1/2 to 2 inches (don't expect you to) they would look like the original CYB megs. Good Job, CliffC
Spargett
Post by Spargett » Thu Jun 24, 2010 10:37 am
What about the center stand hitting the underside of the Dusnstalls? Is there enough safe clearance?
Mike Mullins
muffler clearance
Post by Mike Mullins » Fri Jun 25, 2010 6:07 pm
Scott: yes the centerstand does clear, and just barely. It actually worked out pretty well. I have a rubber bumper on the centerstand (I think) and that makes the difference. By the way, your bike is looking really nice !
Mikeyrx
66 CB 77
76 BMW R75/6
99 GL 1500 trike
75 & 79 XS 650's
Goodysnap
Post by Goodysnap » Fri Jun 25, 2010 7:59 pm
Looks good Mike, I'm thinkin about puttin on a set myself this winter. As the shorties sound really cool but get quite annoying on longer rides. Ear plugs or buds required, if you now what I mean. Take care, Brent
64' CB77
65' CB160
Mike Mullins
Dunstall (Emgo) mufflers
Post by Mike Mullins » Fri Jun 25, 2010 9:07 pm
Brent: Really enjoyed talking to you and seeing you bike at the Gilmore show. I think you would like these mufflers. For the price, I dont think they can be beat. They look good ( well, so far they look good.) and the price is right. They sound pretty good (not great, but actually not bad either.) They were easy to install.
Did you get the other issue you had posted (charging or something) sorted out ?
Mike
66 CB 77
76 BMW R75/6
99 GL 1500 trike
75 & 79 XS 650's
Spargett
Re: muffler clearance
Post by Spargett » Fri Jun 25, 2010 9:15 pm
Thank you. So I assume you have them tucked quite a bit.
Mike Mullins wrote:Scott: yes the centerstand does clear, and just barely. It actually worked out pretty well. I have a rubber bumper on the centerstand (I think) and that makes the difference. By the way, your bike is looking really nice!
