Quick question - can you fit the 1 piece exhaust/silencer to any of the CB72/77s
or does it need different mounting brackets ?
Can you ix and match so 1 piece on one side and 2 piece on the other ... ?
thanks
Phil
One Piece Exhaust/Silencer CB72/77 fits all ?
Re: One Piece Exhaust/Silencer CB72/77 fits all ?
If the muffler has the mounting bracket which mounts to the middle and ya have the correct front ring and spacers it will fit.
No problem having the early on one side and the late on the other. ............lm
Phil-UK wrote:Quick question - can you fit the 1 piece exhaust/silencer to any of the CB72/77s
thanks
Phil
RIDE IT DON'T HIDE IT!
- Contact:
two different mufflers
Be carefull when you mount two different mufflers on a cb72 / 77, make sure the mufflers have the same internals, else I strongly advise you to look for two the same mufflers.
Different mufflers have different internals and thus different ways of working.
I did a lot of testing with different muffler pares (on the dynoyet) and the early two piece systems are more open and revhappy compared two the later one piece mufflers, also the sound of the mufflers are different. Different mufflers aquire also different carbs and settings, the danger having a to lean micxture in one of the cilinders is big.
Using two different mufflers can lead to expensive damage to the pistons, cilinders and crank.
Re: two different mufflers
THE QUESTION/ANSWER WAS FOR THE HONDA CB72/77 MUFFLERS. HONDA ISSUED A MUFFLER SYSTEM AFTER/AT THE END OF PRODUCTION WHICH HAD THE HEAD PIPE PERMANENTLY ATTACHED THE MUFFLER. THE MAKE-UP OF THE MUFFLER WAS THE SAME AS THE EARLY AND USED THE SAME BAFFLE SO I EXPECT YA CAN MIX/MATCH WITHOUT A PROBLEM IN THE ENGINE. ......lm
jensen wrote:Hi,
