Electronic Ignition is Back !!!rgtaylor2
the coils from local honda dealer. I believe they are available most any place. confidence is the best thing I got from the mod. At this time it runs well for me. I feel I'm getting a reliable and strong fire for my ignition. I only have 150 miles with this set up. I've tried to put it through a test of stop/start, hard accel. top end speed (72mph) , idle around, in town traffic and I even left it out side over night in 27deg weather, it fired right up . The temp. around here is low to mid 40's during the days. Spring and summer may show a little differance. One last thing I have no experience with this bike before I installed the system. I bought it not running. It had been sitting many years. I have a lot to lean about the 305. I'm enjoying it with the aid of this forum. LM helped me with the parts(cables, bars and tank) necessary to make it rideable.
i recently installed the e ignition on my CB77
i made a bracket to install it in front of the battery in between the air filters i put some heat sink on the side of the e ignition unit to aid heat dissipation it fits like this it is nicely tugged in between the air filters but not enclosed so cooling will not be compromised fred
Take a quick look at the front of the tool box and ya can/will find a flat and angular down surface which I attach the brain to. No special parts and in the same area ya installed yours.
Just the way I do things. .............lm
RIDE IT DON'T HIDE IT!
Re: Electronic Ignition is Back !!!how can I purchase all the parts for the ignition upagrade and will it work for a cb350 thanks for all the help
