Oil filter o-rings
lhz55
Post by lhz55 » Tue Jul 29, 2008 7:39 am
Is the dash number available. It would help my search.
Thanks, Lee
~Aron~
orings
Post by ~Aron~ » Tue Jul 29, 2008 7:58 am
SKU: 91303-PH8-010
O-RING (79.4X3.1) (Honda Code 1994359) Outer
SKU: 91309-700-010
O-RING (74.5X3) (Honda Code 0002725) Inner
1967 CL77 Owner (work in progress)
lhz55
Post by lhz55 » Tue Jul 29, 2008 8:21 am
Thank You,
Lee
lhz55
Post by lhz55 » Tue Jul 29, 2008 8:43 am
Thank You very much. My basket case restore only had the inner gasket on it. I did not realize their was an inner and outer until your reply.
Once again thank You.
Lee
56_oval
Post by 56_oval » Wed Mar 30, 2011 3:49 pm
I know this is an old post, but where do the o-rings go? Is there a lip for the inner and outer? I'm asking cause my gasket set didn't come with any and my engine leaks oil from the oil filter cover.
Post by davomoto » Wed Mar 30, 2011 4:46 pm
There's a lip for the inner, and tthe outer goes against the cover.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
56_oval
Post by 56_oval » Thu Mar 31, 2011 4:32 pm
So I found a set of 79 and 75mm orings. They were way too large. Is there a difference in side covers? Early and late? My bike is a '64
