REUSE OLD GASKETS??
bk305
REUSE OLD GASKETS??
Post by bk305 » Tue Jun 10, 2008 8:31 am
I KNOW THAT NEW GASKETS ARE BEST AND TOP END GASKETS CAN BE REUSED IF IN GOOD SHAPE BUT- WHAT ARE THE THOUGHTS ABOUT REUSING A VERY SLIGHTLY USED ( 1 HR RUN) CB 77 HEAD GASKET? I THOUGHT MAYBE IF I USED PERMATEX SPRAY COPPER GASKET SEALANT, THIS WOULD WORK? ANOTHER FACTOR I HEARD WAS, ONCE COMPRESSED THIS WOULD BE THE LAST TIME TO USE A HEAD GASKET. ANY IDEAS ?? BK
bigscooter
Post by bigscooter » Thu Jun 12, 2008 12:26 am
it might seal and be fine, but it's a long way back in there if it doesn't seal. i would just order a new one.
Re: REUSE OLD GASKETS??
Post by LOUD MOUSE » Thu Jun 12, 2008 1:06 am
I'd suppose if all the surfaces are clean and dry you can use the gasket once more. ...............lm
quote="bk305"]I KNOW THAT NEW GASKETS ARE BEST AND TOP END GASKETS CAN BE REUSED IF IN GOOD SHAPE BUT- WHAT ARE THE THOUGHTS ABOUT REUSING A VERY SLIGHTLY USED ( 1 HR RUN) CB 77 HEAD GASKET? I THOUGHT MAYBE IF I USED PERMATEX SPRAY COPPER GASKET SEALANT, THIS WOULD WORK? ANOTHER FACTOR I HEARD WAS, ONCE COMPRESSED THIS WOULD BE THE LAST TIME TO USE A HEAD GASKET. ANY IDEAS ?? BK[/uote]
RIDE IT DON'T HIDE IT!
bk305
Post by bk305 » Thu Jun 12, 2008 7:41 am
THANKS GUYS- I'M STILL UNDECIDED WHICH WAY TO GO BUT MAYBE IT'S NOT WORTH THE RISK AFTER TEARING IT ALL APART, TO GO USED? AND HAVE TO GO BACK IN LATER!?!?!? BK
bigscooter
Post by bigscooter » Mon Aug 04, 2008 1:52 pm
bk305 wrote:I KNOW THAT NEW GASKETS ARE BEST AND TOP END GASKETS CAN BE REUSED IF IN GOOD SHAPE BUT- WHAT ARE THE THOUGHTS ABOUT REUSING A VERY SLIGHTLY USED ( 1 HR RUN) CB 77 HEAD GASKET? I THOUGHT MAYBE IF I USED PERMATEX SPRAY COPPER GASKET SEALANT, THIS WOULD WORK? ANOTHER FACTOR I HEARD WAS, ONCE COMPRESSED THIS WOULD BE THE LAST TIME TO USE A HEAD GASKET. ANY IDEAS ?? BK
wow! i've just been head gasket shopping myself, those things are spendy.
maybe i would try to use it again.
joeweir1
Post by joeweir1 » Mon Aug 04, 2008 8:08 pm
You can get an entire gasket set for less than $40.00 I believe.Try Retro Bikes.
Vince Lupo
Post by Vince Lupo » Thu Aug 07, 2008 12:45 am
Tim McDowell at Classic Honda Restoration/The Cycle Vault in Elkridge, MD has gasket sets too.
About $ 49.00
