Really stupid newbie question.....
KentuckyDream
Post by KentuckyDream » Sun Jun 08, 2008 9:55 am
I recently aquired a 69 ca77. The previous owner started to replace some of the hoses coming out of the engine. He did not reconnect them during transport. I have very little engine knowledge, and have not yet received Bill Silvers cdrom. Where do the two hoses go?
joeweir1
Post by joeweir1 » Sun Jun 08, 2008 10:10 am
Are you talking about the two breather hoses coming off back side of the top end?If so they route back to the air filter.Should be two holes in it.Thats how the ones I have had were.
KentuckyDream
Post by KentuckyDream » Sun Jun 08, 2008 10:24 am
joeweir1 wrote:Are you talking about the two breather hoses coming off back side of the top end?If so they route back to the air filter.Should be two holes in it.Thats how the ones I have had were.
I believe they are breather hoses, but what he did is use two different types of hoses, one clear and one black so it is throwing me off. If anyone could post any pictures I would be eternally grateful. Also, would these hoses keep the bike from turning over?
joeweir1
Post by joeweir1 » Sun Jun 08, 2008 12:32 pm
I bought some clear hose at the hardware store and put it on.Not rocket science.Just connect them to the nipples and if you have a stock air filter run them back and stick them in the two holes.If no stock filter I'm not sure what others do with them?Probably just lay they down near back of engine were they won't be blocked.Maybe someone else has other ideas?These being disconnected will not cause it to "not " run.Only issue would be possible if the breathers were clogged and I'm not sure what would happen then.Never had one clogged.
KentuckyDream
Post by KentuckyDream » Tue Jun 10, 2008 1:21 pm
Ok, taken care of those. Now what about the one coming from on top of the engine?
joeweir1
Post by joeweir1 » Tue Jun 10, 2008 3:46 pm
Is hose still there?Should be a long hose.Just runs to the back of the engine from the ones I have seen and lays there.Not sure if anyone else has seen different.Just going by the few I rore down and where mine is.
KentuckyDream
Post by KentuckyDream » Tue Jun 10, 2008 3:58 pm
joeweir1 wrote:Is hose still there?Should be a long hose.Just runs to the back of the engine from the ones I have seen and lays there.Not sure if anyone else has seen different.Just going by the few I rore down and where mine is.
Ok, now why does there appear to be oil coming out of the one on top?!!??
